Main bar label position
I'm using ProStructures Connect Edition Update 3 V10.03.00.58.
I'm trying to place Rebar labels and want the label to be adjacent to the leader line.
I do no need any extra line off of the leader line.
I've changed position to adjacent  or centered but same issue comes up, extra line.
This is what I would like to achieve below.
This function worked in previous version of Power Rebar.
  • Hi Nicole,
    Thanks for raising this request. We will check this if any possibilities are there to achieve your result.
    if not then we need to report this as an Enhancement.
    Sandip Kar
    Product Engineer - Bentley Systems
  • Sandip,
    appreciate you looking into this.
    Hopefully there is a different solution other than enhancement.
    However, if no solution is found,  this would not need to be reported as an enhancement if the developers would have just transferred some of the functionality that was working in previous Rebar versions instead of eliminating them in the first place, especially one that seems quite simple and straight forward as this one.
    I believe this would go a long way to quickly and smoothly transition users from PowerRebar to Proconcrete Connect Edition if functionality of tools were transferred.
    I know I'm not the only person who finds this quite frustrating and needless to say impedes workflow as I'm trying different scenarios to see why this isn't working now.
    Nicole Joyal
    Bridges & Highway Structures
    Manitoba Infrastructure
    Canada
  • My apologies. I just found the setting in the supplied display.sys file that the PLBS settings for oblique and angle lock where set to 0.
    I modified both of these to 1 and now I can place label the way I need.
    Nicole Joyal
    Canada
Reply Children
