Hi
I am working in Prostructures CONNECT Edition Update 3 - Version 10.03.00.58.
Until recently everything was working well but in the last day or 2 some of the "Concrete Placement" and "Rebar Placement" tools do NOT appear. So far the following tools do not appear when I try to activate them:
Has anyone else noticed this? Is there some solution to resolve this issue?
Any help would be appreciated.
Hello Keith, Thanks for posting your query over the Bentley Communities Forum.The issue you are facing may be due to the dialog boxes of the respective tools appearing off screen. This typically happens when you are working on extended monitors. You can refer the below Wiki Link and apply the same to resolve your issue.
Regards,Alistair Lobo
