Setting up Company based seed files for Automatic sheet generation using Callouts in ProConcrete CE
Currently New user to Pro Concrete CE
looking to setup custom company based seed file/files for use during Section call outs for auto sheet generation.
i have copied the default DrawingSeed.dgnlib file (C:\Program Files\Bentley\ProStructures CONNECT Edition\ProStructures\Default\Dgnlib\DrawComp\en)
added the new file to our server workspace and created the required sheets within this file.
when modifying the Configuration Variable to point to this new Drawing seed file, every configuration variable i have modified has had no success in allowing these seed files to be displayed within the drop down menu for section call out seed sheet files.
can someone confirm the correct configuration variable to modify which controls the seed files shown within this drop down menu.
Parents Reply
  • I'm trying to do same as Hayden.
    We are using ProConcrete CE update 3.
    Our workset is USA_Canada_Metric. I've tried to re-create the ProStructureDetailingSymbolStyles.dgnlib by using the metric3d .dgn seed file as we  need to have units in metric metres and millimetres. Copied all elements and models (did not import) from the imperial dgn lib into new dgnlib metric one. I seem to always get this Alert message opening up every time open a different model within this file. Also when I go to see units they still have imperial settings. How can I fix? or is there a metric detailing symbol styles file available?
    Nicole Joyal
    Bridges & Highway Structures
    Manitoba Infrastructure
    Canada
