Trim Rebar by Perpendicular method
Trim Rebar by perpendicular does not seem to trim. I have tried using several points perpendicular to the line I want to cut, but it does not cut. I also find this misleading as a point perpendicular to the bar doesn't make sense, but should be along a point parallel to the bar. The other two methods line, and points are based on drawing a line perpendicular across the bar. Am I missing something?
  • Dear. Mr. Bodnaruk, we will check your issues and come back with explanations and maybe instruction videos. The modification functions will improved when needed.
    Bentley Structural YouTube Channel
    Bentley Technical Support
    Johannes Michalowsky
    User Success Support - Bentley Systems
    ServiceRequest Manager
  • Hi Donald,
    I have checked and it is working fine. if you want to trim any particular rebar from the set, just select that Bar and choose "P for perpendicular" and place two points perpendicular to the bar. After then it will prompt you which side of that line you want trim. Select the side and the bar will be trimmed. Attached one short video which may explain you with more clarity.
    Also please do let us know, which tool you used to place the rebars and also in which ProConcrete Update you are working?
    Sandip Kar
    Product Engineer - Bentley Systems
