I am finding some difficulty in checking bolt properties.In the AISC can't find Pitch height, pitch per unit length and also can't find the Width across corners dimension.I am attaching AISC table for easy finding of references..
Can anyone suggest references for these values ?
In our NASC.mdb, for A325 this values for Prosteel are not needed. you find F/W = Key width and H = Head height. Grip ax and Grip min give you the maximum, and Minimum Grip length. (you have to substract the washer and nut thickness to get the calculated grip length. Pitch values are not calculated and needed in our Product.
Bentley Structural YouTube Channel
Bentley Technical Support
Johannes Michalowsky
User Success Support - Bentley Systems
ServiceRequest Manager
