How can I view current bar cover for a zone (set) of bars and then modify it? I don't see any tools that can do this.
Tom Ciha
Regards,Sandip KarProduct Engineer - Bentley Systems
Sandip,
I updated my profile 2 days ago, including contact information. Let me know if you need other information.
Please see image below. I'm needed to know how I can edit the bar cover by raising or lowering the entire matt of rebar in the floor of my structure. Similarly, how can I lengthen or shorten all vertical bars in the walls? It seems that the Rebar Modification ribbon only allows for modifying one rebar at a time.
Is there a good way to measure or view the current bar cover?
I was able to resolve this issue. I didn't notice that I can go to Edit Rebar, then change end condition and apply it to the rebar zone.
