I need to print a 3D pdf, but it will only come out in monochrome. I need the pdf in color. Screen shots are below. On the print screen, after selecting "Print to 3D", the preview window shows the print to be in color. Is there a setting that needs to be changed? Note that I'm able to print a normal (2D) pdf in color, just not the 3D.
Thank You,
Tom Ciha
Hi Thomas,
In Area, please select Fence Option and follow the below steps
1. In 3D model Select Area with Fence
2. Then go for Printing
3. When you are in Fence Selection, you can see Color option is active. You can select True Color then.
I hope this can resolve your issue.
Regards,Sandip KarProduct Engineer - Bentley Systems
Sandip,
I placed the fence per your steps, however, the color option is still inactive. Please see the screenshot.
Just Check off the Print to 3D box and then you can see the Color option is activated to change.
After our conversation, I printed to adobe acrobat and still had the same problem with no color. Could there possibly be other settings in Prostructures that need to be checked?
Tom
