1- In rebar set such as Irregular Dispatch reinforcing please add properties rebar cover for each face when select. For now must create guide line then move and edit, it need many times
2- And when make many rebar set each layer will automatic set or manually change layer set
Hoa
Hi Hoa,
Irregular Dispatch method is completely custom reinforcing category and in this method the reinforcing follows the guidelines. So whatever cover you need, you can set while placing the guidelines.
Also in further extent you can use Variable and Constraints so that it can react according to the variable.
See the attached video to get idea, how you can play with Variables and constraints to work with reinforcing.
Hope you will get much clarity after viewing this video. Do let me know if you need any further help on this.
Regards,Sandip KarProduct Engineer - Bentley Systems
Hi Sandip Kar,
Thank you for quick reply
1- About the cover I need is when I place rebar set the rebar will offset with surface of guidelines, it is cover with concrete part.
2- Layer rebar: example the rebar layer 1 was place then rebar layer 2 will automatic can offset one dia of rebar layer 1. And the layer can changer.
