I'm using Prostructures Connect Edition Update 4 V.10.04.00.47.
Since I cannot use the Rebar section view tools in Prostructures to create my drawings correctly (was told the issue will be resolved in updated version)
Since I can't wait for new version I'm having to re-create my section views and now use them in Power Rebar.
I tried using File Export to visible edges on the section view and export to :2F file, 3d file or Active file. None of these worked.
I get a message 3D only tool.
So how can I get this section view saved as a 2d file and or visible edges file to use in Power Rebar?
Any direction and or assistance would be appreciated.
Hi Nicole, Thanks for posting your query over the Bentley Communities Forum. We have set up a Webex meeting with you to discuss this issue in brief and better understand your requirement. Regards, Alistair Lobo
Nicole Joyal
Bridges & Highway Structures
Manitoba Infrastructure
Canada
Work around :From ProStructures one can do a File, Export to V8 dgn format.
Under Options, Filter, select the section view models required. Under the References tab check on Merge Visible Edges of 3D Attachments.
Now I have my section views ready to use in Power Rebar.
File Save as worked for me. Not export as I was getting error message.
Thanks Nicole for this update and happy to hear that you have found the workaround. However you will not find issue in upcoming release Update 5, which is going to release very soon.
Regards,Sandip KarProduct Engineer - Bentley Systems
