Hi Guy,
I just test workflow model from OBD reference to PS
I test for two footings.
1- Footing rectangular the rebar is working correct with concrete part, when model change rebar is change
2-Footing with Trap rak 1900x1900 the rebar is working not correct
3-Can I transfer or link or best other way to working Column grid in OBD and Workframe in PS?
Please check and disscus about workflow OBD and PS for Structure detailing at this topic!
Hi Hoa,
For the second case you can use Slab Reinforcing with Option Concrete/Define Points or Polyline option.
And take the points of your shape at outer edges or can place on predefined polyline. I hope this will solve your issue.
Do let me know if you are not clear on this.
Regards,Sandip KarProduct Engineer - Bentley Systems
Dear Sandip Kar,
I also agree with you with case 2: using the rebar set -slab. But if any please improve the pad footing reinforcing can place rebar for this case?
And can you have opinion in case 3: to coo-working between column grid in OBD and workframe in PS?
