Positioning giving same group position number for different groups. I find 11 different groups. Program find only 7.
My working file:
drive.google.com/.../view
Hello Gintaras,Thanks for posting your query over the Bentley Community Forum.
Please allow us some time to check on this issue and we will get back to you.
Kind Regards,Vyanktesh NamaSenior Technical Support Engineer Bentley SystemsBentley Structural YouTube ChannelBentley Technical Support
HI sir,,,I am learning to use the prostructures for the staadpro connect edition V22.However,i am not able to open the model in prostructures connect edition.The ISM link seems to be broken.please suggest other methods of opening the staad file in prostructures.
Hello Ajay, Thanks for posting your query over the Bentley Communities Forum. With reference to your issue, can you please confirm the versions of STAAD.Pro, Structral Synchronizer and ProStructures that you are using. Also, it would be great if you could share your contact details so that we can discuss this issue in more detail. Regards, Alistair Lobo
Sir,....my staadpro CE is V22. update 2, and the prostructures is connect edition v10.02.00 ...i am not able to create ISM file in staadpro CE as it gives error saying install structural syncroniser for for ism 6.0....please advice how to use prostructures as standalone if connection is not possible.Many thanks.
Hi, Ajay
you need STAAD CE Update4(22.04.00.40), ProStructures CE Update5(10.05.00.XX) and Structural Synchronizer CONNECT Edition V11 Update 1(11.01.01.04) for exporting STAAD to ProStructures by ISM, please reference below video for detail, sorry video is speaking in Chinese, any question, let me know
