Hi Guys,
I have some typical rebar mark same as below, please let me know how to create it in ProStrucutres
Option 1: typical for column
Option 2: typical for beam
Option 3: typical for wall on plan
Thanks all
Hello Nguyen, Thanks for posting your query over the Bentley Communities Forum. In reference to the issue you have raised, can you please confirm as to what rebar information you would like to add as notes / labels / annotations to the 2D model for detailing the same. Regards, Alistair Lobo
in my post the rebar mark information explain below
Thank you so much
Hello Nguyen, In response to your query, you can add labels to rebars and use the presets to define to information that you require.
Like in the above case, I have added presets to define the rebar diameter and spacing, along with the bar mark at the bottom. Similarly, you can add such presets in various permutations and display the information you require. Please let me know if this resolves your issue. Regards, Alistair Lobo
In the mark I want the rebar mark ( position ) inner the circle?
Can you have more way to make it?
Hello Nguyen, Please allow me sometime to check for that. I will revert shortly. Regards, Alistair Lobo
