Hi Guy,
I have one issue is I can not delete one rebar in model. Please see my video and file for detail
https://youtu.be/56rsyeK2v5Y
KENH THANG.dgn
Hi Nguyen, Thanks for posting your query over the Bentley Communities Forum. We will check for the video & file that you have attached and revert shortly. Regards, Alistair Lobo
Hello Nguyen, We have investigated your model and found that the element you are trying to delete seems to be corrupt. In this situation, we recommend you to delete this by selecting the element and using the analyze element deletebyid XXXXXX key-in, where XXXXXX is the Rebar element ID as seen in the below picture For this, please refer the below attached Wiki -
Hi Alistair,
It work fine thank you so much.
Answer Verified By: Phong
