Single rebar distribution
Hi Guy,
I trying make stirrup for curve beam using single rebar distribution but it not workfine.
  • Hi Hoa,
    It should work. However you can make it even via irregular dispatch tool too. Let me ho through this and will get back to you with one short video.
    Sandip Kar
    Product Engineer - Bentley Systems
  • Hi Hoa,
    Please go through this attached video in the link.
    https://bentley.sharefile.com/d-s4c22930f6d442fa8
    The workflow followed here
    1. Using FBRM, extracted faces and then using Associative Intersection, created guide lines which are following the curvature.
    2. Then used Irregular Dispatch method to place the Stirrups.
    However using Single Rebar distributoion is good when there is straight path.
    Sandip Kar
  • Hi Sandip Kar,
    Thank you for video.
    Can you make more video to create main bar for this beam.
    Best regards,
    Hoa
  • Hi Hoa,
    Hope you are doing well. Sorry for my late response. I have created a short video explaining how to create Longitudinal Bars and Stirrups in a curved block following the curvature. Hope this will help you to get more clarity on how to achieve this kind of reinforcement.
    By in ProStructures > ProStructures Files
    Sandip Kar
  • Dear Sandip Kar,
    Thank you so much I will try and feedback to you
Reply Children
