Hi, my name is Massimo and i used proconcrete Connect update 4
with comand "Modify Rebar" I identify 3f24 Pos2 Length 3235 mm with string "$n%%c$d $ll L=$ql"; in particular with string $ql proconcrete returns the total length of bar.
But if I measure the total length is 3189 mm instead 3235mm. Normally thi is not a problem; but in this case the junction is mechanic and 50 mm does difference.
I'd like to know where I make a mistake.
thank you very much.
Best regards and sorry for my english.
Regards,Sandip KarProduct Engineer - Bentley Systems
Hi Sandip,
of course, I'll send to you by email because I don't know through community.
Best regards.
Massimo
