We deliver to our customer reinforcement IFC models. Customer based on the model preparing bill of quantities using some dedicated software. The point that is by default all components of Pset_ProStructures_Rebar_Properties and Pset_ProStructures_RebarAssembly_Properties are written to IFC file as a strings, and the customer software reading reinforcement weight (mass) expects numbers.
I have change weight mapping inside IfcElementAssembly.att and IfcReinforcingBar.att files from IfcLabel to IfcMassMeasure. Finally IFC file contains numbers (double) with unit (kg). But values are given rounded to kilograms. Is there any way to set custom rounding precision for IFC weight attribute? If so how to do it?
By the way, is the Mapping Options available within ProStructure, the way it is implemented if Open Building Designer? Or the manual edit of *.att file is the only way to control IFC file content?
Regards,Bogdan
