Is there a way to generate a persistent connection between two elements, say a column and beam.
If a column is moved the connected beam will stretch to follow the column, or vice versa...
Yes, if you use "cut at object" it creates a linking like this. Also when you use most of the connections.
Bentley Structural YouTube Channel
Bentley Technical Support
Johannes Michalowsky
User Success Support - Bentley Systems
ServiceRequest Manager
