Good afternoon, I ran into the problem of displaying the axes in the section: I create axes using the construction grid function, make a plan - the axes are displayed normally (see attachment 1), I create a section, the axes are not displayed (see attachment 2). How can I customize the display of axes in the section?
For Dynamic Views to have the Grid in the drawing, you need the Column Grid function, or to drop the Grip from Workframe, but this is afterwards a static grid.
For the Detailcenter you use the Workframe Grid
Bentley Structural YouTube Channel
Bentley Technical Support
Johannes Michalowsky
User Success Support - Bentley Systems
ServiceRequest Manager
Unfortunately I cannot get a section with normal display of the axes, I tried the solution you suggested, but nothing changed, maybe there are some other options? Is it also possible there is a video with the correct placement of the axes, including on the cuts?
The column grid system should be in the plane of the dynamic view cut to have it in the sheet layout later.
We will provide a video later for further information.
Thank you, I'll wait for the video
