I'm looking for the efficient way to make a copy of all reinforcement for the concrete member. In my case it is a beam that need to be shifted and 180 degrees rotated. I have found a post refered to the similar issue but it is desribing possible approach for ProConcrete v8i version - PROSTRUCTURE REBAR (COPY, MIRROR, ROTATE) - ProConcrete Forum - ProStructures - Bentley Communities
How about CE version? I was tryinig moving rebars with both "Move rebar" command and standard Microstation "move" command. None of these tries have been sucessfull. And what about rotation? Is there any effective way for rebar rotating?
Regards,Bogdan Majcherczyk
PDF
Many thanks for your request. We will investigate cloning and copy possibilities and come back to you
Bentley Structural YouTube Channel
Bentley Technical Support
Johannes Michalowsky
User Success Support - Bentley Systems
ServiceRequest Manager
Have you got any conclusions regaring the pointed issue?
Regrads,Bogdan
Hi Bogdan,
you can try to copy a new beam with rebar from exsiting beam and then move and rotate it to a good place. At last, you can user a new command reassign the rebar to a new owner, is it reasonable?
That's a new option (command) haven't known. I will check it and let you know if (how) it works.
Kindly remind, This command is only available in ProStructures CE Update5.1
