Hello everyone
I want to add a new type of bar diameter (not included in the standard). But I do not understand what "size" means here?I use SI-metric.Example: Add a steel bar of diameter D38What should I look out for?Thanks for any support
Hello Pham, Thanks for posting your query over the Bentley Communities Forum. We will check for your issue and revert soon. Regards, Alistair Lobo
thank you. I am waiting for instructions on how to add your new bar size
Hello Pham, Thanks for your patience on this issue. We suggest you to please review the steps mentioned in the below Wiki to add a new bar size or edit any existing bar information in the respective Rebar code of your choice -
Alistair Lobo
Thank you A very muchI don't understand what "SIZE="1.75" means?how to calculate the value of "SIZE"?
I want to add a diameter bar D38
