I use to model the continuous beams between the further supports with one beam, then I cut it with feature cut from solids to give continuity to columns, in this way I have much control with the reinforcements over supports in top of the beam and in the middle spans, but I am needing to model a monolithic slab with beams and the setdown to beam tool is unavailable for these cut beams.
Many thanks for your request, it would be great if you have an example model on what you want to achieve, or we can make an online session with you if needed to have a full picture on your requirements.
Bentley Structural YouTube Channel
Bentley Technical Support
Johannes Michalowsky
User Success Support - Bentley Systems
ServiceRequest Manager
I'm sending you five screenshots defining the situation
Hi Manuel, Thanks for sending us the screenshots. We will try checking for this and update you shortly. Also, can you please attach your model so that we can better investigate this. Regards, Alistair Lobo
Sure Alistair...03_ORIGINAL CONCRETE MULTIFRAME_SLABS.dgn
