Beam reinforcement Pin dia issue for longitudinal bars
Hi there,
I'm using ProStructures Connect Edition V.10.05.00.54
I'm trying to place beam reinforcement with a stirrup that has one end a non-standard Pin dia.
Once i modify this stirrup end with either a 90 degree hook with 100 mm pin dia, or a Bend with 100 mm pin dia.
it forces that corner longitudinal bar in space, it no longer is tied to the bend radius.
How can i fix this? If i try moving this bar it disappears.
