I'm using ProStructures Connect Edition 10.05.00.54.
Looking for a search tool for Bar Properties, specifically BarMark field.
I need to locate certain bars to be able to delete or edit so as to fix my project.
I've positioned and created concrete parlist to get my bar marks.
My preview tool Schedule Generator and Manual Marking is not working, I'm getting an error.
Any suggestions on how to locate a certain BarMark without using Schedule Generator?
Hello Nicole, Thanks for posting your query over the Bentley Communities Forum. In response to your query of locating the rebars in your 3D model with respect to the Bar Marks, we suggest to use the Bar Analytics tool. You can go to the Bar Factory tab and select the particular Bar Mark, you will see the sketch in the section below and the same will get highlighted in the 3D model also. Please let us know if this resolves your query. Regards, Alistair Lobo
Thanks Alistair. This helps. However still having a hard time seeing certain highlighted bars in my file.
Is there a way to inhance or change highlight color?
Nicole Joyal
Bridges & Highway Structures
Manitoba Infrastructure
Canada
Hi Nicole, You can try setting / changing the Selection and Highlight colors in the View Options of the Preferences. Hope this helps. Regards, Alistair Lobo
Yes, thanks, i even tried that and i still can't find the barmark in question.The length of this bar is 25 mm, obviously should be deleted, but can't see it even with changing the highlight color.2868 culvert.mdb2868_ProConcrete Rebar.dgn
Here's my files.
Hi Nicole, We recommend you to search for the rebar through the Explorer > Advanced Search
Please let us know if this resolves your issue.
