adding a new bar shape
hi all.
i am trying to add a 'u' shape bar to the rsf file. the program defaults it to a 'L' shape and wont allow me to change it.
we have found a work around by creating a small straight section between 2 bends and then the program defaults it to a 'LL' shape.
this work around is not the correct method and need to have a 'u' shape option.
any help will be appreciated.
  • Hello Richard,
    Thanks for posting your query over the Bentley Communities Forum.
    In response to your issue, can you please attach the model with the concerned bar shape OR send us a picture of the bar shape. Also, can you please confirm which *.rsf file you are using while assigning the bar marks.
    Alistair Lobo
