How to Convert ProConcrete Element to 3D Element
Hello
How to Convert ProConcrete (prosteel) Element to 3D Element (3D solid)
  • Hello Pham Quang Nang,
    Thank you posting your query over Bentley Communities Forum.
    To Convert ProStructures' elements to 3D solids, you can use option 'Create Native Solid Drawing' located under path File>Export>ProStructuresFileTypes. This will convert elements to solids and will be in the .dgn file format.
    If you want to convert ProStructures' elements to solids and save it in other form of file types then you can use other other options available under File>Export>3DModelingFileTypes.
    I hope this clears your concern.
    Mihir Patil.
