Problem with Change Screen option
version Update5 10.05.00.54
please help
Hello Pham, Thanks for posting your query over the Bentley Communities Forum. In reference to your issue, can you elaborate the issue that you are facing.
Also, we recommend to review the below Wikis -
Regards, Alistair Lobo
I have done this installation before
Hi Pham, Can you please confirm what's the exact issue ?
it will look something like this
thank so much
Hi Pham, Can you please confirm if you are looking to set up all the 5 views in 1 application window ?
OR
You want 1 view on each of the 3 application windows ?Regards, Alistair Lobo
I want 1 view on each of the 3 application windows
