I am going through the ProStructures CE training PDF from the Learn Server and need some clarification on page 8. It's a really basic thing I am stuck on.
On page 8 its says to Enable ProS Snaps in order to snap to the edges of the beams. I set the K snap divider to 2, but it only snapped to the center of the column, and I cannot achieve the required connection which has beams flush with the column.
Then while watching the Onboarding video 09-Basic Concrete Modelling (Beam/ Column/Pad Footing/Slab) I noticed that the presenters Enable ProS Snaps is off? This is not even mentioned in the video.
thank you,Rob
Thank you Mihir and Johannes, this has helped... later when I check keypoint snap divisor (Shift K) it was set to 1,i then changed it to 2! I'll have to check/change this in our templates and save settings!
