While converting from dgn to dwg the color property of rebar changes to white ,but in the dgn file it is in magenta.How to get the exact property in dwg file?
Hi Jeyamani,
Thanks for posting your query over the Bentley Communities Forum.
In reference to your issue, can you please confirm the below details -1) Which version of ProConcrete are you working on ?2) What's the method of conversion (from DGN to DWG) you are using ?3) What version of AutoCAD are you opening this file in ?
Regard,Alistair Lobo
I am using prostructures connect edition update 5,I used batch convertor to convert dgn to dwg and I opened dwg file in autocad 16
Answer Verified By: Jeyamani J 20IM004
use the DWG SAVE AS Options . under advanced use the "True Color" option.
MicroStation supports arbitrary, custom color tables, whereas AutoCAD supports only a fixed table. When a color from a MicroStation table is saved to AutoCAD, it can use either the closest color in the AutoCAD table, or a “True Color”. If this setting is checked on, and there is not an exact match in the AutoCAD table, a True Color (RGB) color is used.
Frank
Thank you Sir,It really worked.
