I'm new to ProStructures but have been a user of Openbuildings Designer for about one year now. I'm trying to customize ProStructures a bit to resemble the methodology, mainly the screen menu that pops up when using the ctrl+shift+reset combination.
I found how to do that but I do have a question.
By default in ProStructures this window/menu comes up when using that combo:
However in the "Button assignment" window I don't see it:
It's not a problem to override the command for ctrl+shift+reset, I can easily do that from the button assignment and it works too! But it means I lose the 'default' menu. I'd like to map that to another button combination.
Can anybody help me out which command I need to enter in the "Action" field to get this menu?
Thank you!
Hi Johan,
Thanks for posting your query over the Bentley Communities Forum.You can use Ctrl+Shift+Reset button assignment for your required command and can still get the default context menu using Alt+Shift+Reset combination. I hope, this will resolve your query. Please let us know if you have any doubts on this.
Kind Regards,Vyanktesh NamaSenior Technical Support Engineer Bentley SystemsBentley Structural YouTube ChannelBentley Technical Support
Answer Verified By: Johan De Cock
Hello Vyanktesh,
thank you for your reply! It does resolve my question indeed. Though you didn't answer to what "Action" this corresponds?
I have checked all the options in the Button Assignment dialog as well as in the Custom Tool dialog but not found that action. I think this is hard coded in the application.
OK thank you!
