Hello ProConcrete gurus,
I came across this cool vid showing how some stud framing can be added using some scripting (UDFs, ETs) based on a linear solid (Wall).
I was thinking that the steel studwork frame is pretty straight forward compared to rebar design.
So, I was wondering if there was a way to hack ProStructure's rebar settings to generate steel studwork?
A lot of the same logic, like framing around openings, would apply?
Hi Dominic,
Thanks for posting your query over the Bentley Community Forum. Please allow us some time to check on this issue and we will get back to you.
Kind Regards,Vyanktesh NamaSenior Technical Support Engineer Bentley SystemsBentley Structural YouTube ChannelBentley Technical Support
