I'm trying to figure out how to use ProStructures to use standard welded rebar mesh. Is it possible? The disadvantage off just using the default slab reinforcement is that rebar bending schedules will list all individual rebars.
I found a very old topic with the same question (from 2012) without any replies. I'm hoping in the meantime there is a solution!
Hi Johan,Thank you for raising this query over the Bentley Community Forum.Right now, the dedicated tool for creating welded rebar mesh is not available. However, we have already reported an enhancement for this issue.I m sorry to say that, for now, you need to work with the existing rebar tools. But, in future this tool may be added in the product. How to add a Single Rebar Distribution to Concrete Shape
Thank you for the information.
Is there a method with the current tools to exclude specific bar sets from positioning/marking process? I know I can probably achieve that by not selecting them. But it's easy to use the "select all" and forget that some bars shouldn't be positioned.
