Hi Everyone,I have got the NC data for subgroups plates with their coordinates but was not able to get the data with the position number of these plates.
So,is it possible to get these details in Power pro structure having version V8i 8.11.11.616?Refer to the attached image for more details.we need this urgently for our future structural robot fitting development.
Thanks in Advance!
Hello Vishal, you need to position subgroups during positioning in this case:
Bentley Structural YouTube Channel
Bentley Technical Support
Johannes Michalowsky
User Success Support - Bentley Systems
ServiceRequest Manager
Thanks, Johannes for your Quick reply!
I have tried your suggestion to check NC data but still, the position number is missing there.Can you please suggest what will be the exact issue
Vishal
you will get the attached part number for the viewer and the machine
it is not directly in the visible data.
But this is likely only in newer versions of ProStructures like 10.00.05.xx, please update.
So can i get my exact requirement after updating newer version as you suggest?
here you find all information to the latest version of ProStructures
