I am testing Manual Marking Tool and I can't load the Pad Footing into the Manager. It is possible for all other elements (Beams, Columns, Wall) but not for the Pad Footing. Could You check this out? I have version 10.06.01.59 of Prostructures.
fund1_test.dgn
Grzegorz Zwoniarkiewicz
Hi Grzegorz,
Thanks for posting your query over the Bentley Community Forum.
I have tested this issue in a new dgn file and I can load the Pad Footing into the Manual Bar Mark Manager, please see the below image.
We can reproduce this issue with your attached dgn file and this needs further investigation. So, we request you to please log a service request so that we can check this over the live session, you can refer the below wiki link to the raise the request.
Kind Regards,Vyanktesh NamaSenior Technical Support Engineer Bentley SystemsBentley Structural YouTube ChannelBentley Technical Support
Manual Marking Tools work also on rebars without mark. I tested this on others element. I already found out when it fails to load Pad Footing to Manager. It fails when in Pad Footing Reinforcing, the Spacing is declared. When I choose the Quantity then I can load this Pad Footing into Manager. You can test it in the attached file where there are two Pad Footing one with the Spacing, second with the Quantity declared. I think it must be a bug in program.fund2_test.dgn
Thanks for bringing this point. I tested and found you are right. When Qty. is not mentioned, then it is not populating in manual Bar Marking manager.
This is a Bug and i would like you to create a Service Request so that we can take proper action.
if you are getting difficulties to log SR, you can follow the below Wiki link.
Regards,Sandip KarProduct Engineer - Bentley Systems
I created as You suggested a Service Request.
Thanks for raising the service request (SR#7001448738) as suggested.I would like to inform you that this issue resulted in Bug Report 948910, and will be evaluated by the product management team for our regular CONNECT Edition updates. Meanwhile I would recommend using following workflow: Instead of using spacing option, you could use the quantity option in the Pad Footing Reinforcing tool so that the rebars gets loaded into the Manual Bar Marks Manager.
Answer Verified By: Grzegorz Zwoniarkiewicz
