Hi Guy,
In my country design setting for beam
The rebar stirrup have require below
1) auto divide by 1/4 length of beam span
2) If have secondary beam in span(sub beam) the stirrup will automatic added some stirrups with spacing a=50
Please help me how to use beam reinforcing component to modeling rule above in PS?
Hi Phong,
Thank you for raising your concern over the Bentley Communities Forum.
To meet your requirement, you must define the stirrup zones under General (Beam Reinforcing > Stirrups tab) wherein you can specify the bar diameter, spacing, and location. This will be stored below in the same dialog. To add more zones, click on the Add icon around.You can also lap two (2) zones wherein such cases of secondary beams crossing the girders, additional reinforcements are required. All you need is to manage the rebar spacing and starting points in the lapped zone to achieve the required narrow stirrup arrangement.
For better understanding, I must say that you raise a Service Request so we can have a live discussion. To create one, please follow this Wiki on how to raise a Service Request.
Thank you for your reply
It is not automatic set by 1/4 span of beam length need manually to input
And it can not divide stirrup if have sub beam
