Hı
1st question: How can I make longitudinal reinforcement in a continuous beam as a single reinforcement in a 2,3....n span beam?
2.Question: How do I add Stirrups in 2,3....n span beams.
There is no problem with single span.
5187.test.dgn
1)1.st floor pour concrete column
2.)1.st floor pour concrete beam and slab
3)2.st floor pour concrete column
4) 1.st floor pour concrete beam and slab
Hi Erkan,Thanks for posting your query over the Bentley Community Forum.We'll check the DGN file you provide and answer your queries according to your model.Thanks & best regards,Kemuel JancordaTechnical Support EngineerBentley SystemsBentley Structural YouTube ChannelBentley Technical Support
In multiple beams, if I make a single beam, there is a problem in naming it. When I design the beam alone, when I cut the beam, 2 beams are in one name. If I design multiple beams, how will I place the longitudinal reinforcement?
In other words, if there is a command that combines 2.3 ...n longitudinal beam reinforcement and a command that automatically combines it from 12 meters, the projects will be drawn faster.
I think it will be very fast if the beams are designed one by one and the longitudinal reinforcements are combined with a single application. Also, if it is automatically combined every 12 meters, it will be magnificent.
Hi Erkan,I have reviewed your queries. Here are my comments.
1. To place a continuous main bar reinforcement along a beam, use the Offset option under Reinforcing Data to extend the main reinforcements. We can understand that these are crucial to placement of stirrups especially the 4 bars at corners.
2. So for your second query, I suggest you to maintain the zoning data when creating individual stirrups on other parts of the continuous beam. See image below.
For the rest of the reinforcing bars, I recommend to use a single beam reinforcing tool. These include the continuous bars, extra bars, and midspan at top and bottom, etc. For the splicing the longitudinal bars, I suggest you to use the rebar modification tool - Lap/Splice Rebar to perform multiple splices manually at required splice zones.
I will share with you the sample continuous beam I made. Here's the link for the file.We understand that there are still limitations in the program to model fast a continuous beam. Your suggestions are good candidates for enhancement. We would appreciate if you share your idea to our ProStructures Ideas Portal.
Answer Verified By: ERKAN EYMUR
