Prosteel detail style questions
I would like to ask some help with regards to extracting plans and elevations using detail styles.
1. How can I exagerate the web and flange thickness? When the scale is small, I can not see the web and flange as it looks like one line. Can I exagerate the thickness of web and flange?
2. Is there a way to have the labels in 2 lines? When there is a small beam, the label won`t fit. Like when I want to show the member size and elevation for example - W200X26 (-200). is there a way to have the W200X26 at the top of the beam and (-200) at the bottom of the beam?
3. If I have a plan with some beams lower or higher than the plan elevation. For example there is W200X36, W200X36 (+200) and W200X36 (-200). What should I do to show this labels?
