Im trying to install Prosteel version 08.11.04.42 on microstation v8i ss3. The installationpackage cant seem to find microstation...so I guess its not possible at the moment.
When will Prosteel for microstation be installable on Microstation V8i SS3?
Is it possible to first install SS2 then prosteel and after that upgrade SS2 to SS3?...will Prosteel still run?
You need for Series3 --Prostructures-- on Microstation 8.11.10.36 on SELECT. 8.11.4.42 is only compatible with Series2. Thisv is the older version, the new version of ProStructures run on Series2 of MicroStation too.
Best regards Johannes Michalowsky
TSG
Bentley Structural YouTube Channel
Bentley Technical Support
User Success Support - Bentley Systems
ServiceRequest Manager
How bad! There is some advantages in SS3 that the prosteel users also want to take advantage of.
Just to clarify. ProStructures is combined Prosteel and ProConcrete. So you will use the ProStructure Download in the future anyway, just uncheck in your license selection ProConcrete.
Answer Verified By: Johannes Michalowsky
