Hello All,
I would like to clarfied to increase the Text Width Factor in Detail Style.
Devaraj.S
Devaraj, what text width you want to increase (detail description, Shape Label)? More details of your inquire may help (any screenshot what you want to achieve).
Basically Text and Dimension sizes are control by platform AutoCAD or MicroStation set Text Styles or Dimensions Styles.
Answer Verified By: Roger Belen
If you create a text Style or Dimension style within AutoCAD or MicroStation, those Styles will be accessible in the ProStructures Dialog boxes that requires Text Style and or Dimension styles.
In ProStructures Series6 you should use PS_Textflag and create a template and use that in the Detailstyle.
In former older versions like mentioned above the txtstyle is directly applied, even though in some former versions of ProStructure the width factor was not applied.
Which version are you using ?
Bentley Structural YouTube Channel
Bentley Technical Support
Johannes Michalowsky
User Success Support - Bentley Systems
ServiceRequest Manager
Hello
But, how we can change width factor in Position Flag in MS Connect edition? Every time the values back to original position. Then, the position number is too wide.
