Dear Bentley Family,
When we go under menu:
Prostructures>2d>Detail Centre> Detail Centre standard>Views>Selected Details views>Create 2d>Preview>Following Fatal Error getting for this particular drawing file only. After clicking on OK it throws/close the application.
We also tried to save as the file to other name & location then also its giving the same error.
We also tried to Auto-recover the file then also its giving the same error.
The error screenshot is attached here.
Please let us know any solution to fix this error, our this project work is completely stop.
Waiting for your earliest reply.
Note - We are using:
Software : Bentley V8i - SS4 version : 8.11.9.65 , Autocad 2012-64Bit , Naviswork 2013 , Inventor Ultimate 2014-64 Bit , MS-Office 2010 - 64 Bit.
Hardware : Workstation Dell Precision T3600
If it's a work stoppage, why not export the steel to PSB format, then import it back into a new model. If you reference the old model, you might even be able to copy and paste the workframe views back into the model. Maybe it would work if all steel/views were generated in a new model in this way?
Answer Verified By: Swapnil M Gholap
Thank you very much.
It solved our Fatal error issue.
Thanks & Regards ,
Swapnil M. Gholap
Application Engineer
s.gholap@frames-group.com
Frames Process & Energy Systems India Pvt.Ltd.
www.frames-group.com
