Whenever I created drawings in section or elevation view gridline is not appearing in my drawings, but in plan its always appearing. Please help how can I make it appear gridline in my drawing extraction section plan.
Thank you
Marc
Answer Verified By: IronMaxSteel
Hi!
To view grid lines on sections you need to do the following:
1. Go to drawing model on which you want to view the grid lines.
2. Select "Set Reference Presentation on Drawing Composition Tab
3. Click on any element on the drawing.
4. In Reference Presentation Dialog Box check "Show Grid System" option and press OK
You should be able to see the grids after that:
Hope it helps.
