My File ERROR.dgn
Hi.
Instead of $BN please try $kl.
It gave me result shown below.
Is this correct?
Answer Verified By: Binh Le Dang
Hi Michal Lipinski
I ask addtional me , Why I can't modify Bar Mark Macro ?
Thank you so much
To change Bar Marks you have to change Rebar Code first. After doing so, greyed out fields will be accessible again.
I am attaching a video to explain.
First part shows your model and switching to a different, rebar code which will unlock assigning new bar mark macro.
Second part shows an example when you want to reset Bar Marks but you want to use the same code.
You have to copy the one that you are currently using, change its name and mark it as current.
After this you will be able to assign new bar mark macro again.
I have a problem in positioning.
how to change bar mark ?
for example : T2 equal T10
Thank you so much !!!
Please help me.
My file :
new block.dgn
