I'm currently using Rebar V08.11.07.55,
haven't upgraded to Power Rebar as we had issues with Bar Charts mark numbering issues,
not allowing a preceeding number as set in our sys file. So we are waiting for next release.
When placing a one legged bar it will detail all required lengths including non stock lengths,
as have set our Main Bar defaults to auto lap when stock length exceeded.
We want to have our stock lengths show up in our bar charts and not just the total length for this bar.
We don't want to have to spend extra time placing stock lengths individually when the system
details them correctly already.
Is there a sys file setup to get this done? I could not find any.
Nicole
Drew a 1 legged bar:
The stock length is 60’, the lap is 3’-7” and the last bar is 25’-6”.
Here is the bar chart:
In the bar chart you need to define D, B, E, C, N and the Nominal length. For the chart above I had the following:
COL_DIA 11.25 15 Centre // Diameter
COL_MARK 22 29 Centre ~$bn~ // Bar Mark Text generated from the "MTXT" display.sys parameter.
COL_LNOM 37.5 46 Centre // "Nominal" total length
COL_TOTAL 52.5 59 Centre // Total number of bars
COL_SHAPE_CODE 62.75 66.5 Centre // Bar Shape Number
COL_B 115.5 124.5 Centre
COL_C 133.5 142.5 Centre
COL_D 151.5 160.5 Centre
COL_E 169.5 178.5 Centre
COL_N 254.5 260 Centre
Dilip
