HI,
I'm currently using the Prostructure SS6 in Autocad and I'm having a trouble to create the Drawing partlist to the drawing, every time I created the Template for drawing partlist the Part list I created does not showed up in the drawing and the default template (Standard/Standard) always appeared.
I set the following
After I set the drawing partlist and then run the 2d export
the Drawing part list I Created still not appear instead the default template showed up (See below Image)
Answer Verified By: Johannes Michalowsky
Hi Edger,
Thanks for informing us that the issue been resolved by your own.
Regards,Sandip KarProduct Engineer - Bentley Systems
