I need to provide detail drawings for square to round transition. I have tried to use the command ProStructure Place Solid RectToCircle in Prosteel but nothing happens. I had to do this using the key in function because the command is not shown int the pick menu of PS Solids. Other commands from the PS Solids menu do work. Any suggestions? I also have an Aecosim licence. Which would be the best program to get the information from and how?
ProStructure
Place
Solid
RectToCircle
Brian
one can do feature solids square to circle and promote them to a Prosteel solid reference. The command you mentioned became obsolete.
Bentley Structural YouTube Channel
Bentley Technical Support
Johannes Michalowsky
User Success Support - Bentley Systems
ServiceRequest Manager
Senior Highway Design
ZUTARI SOUTH AFRICA & AURECON
its in T2, Solid Reference
Thanks Johannes
