Dimension Annotation Scale is not working in Prostructures SS7
Power Prostructure SS7 -
Whenever I created 3d model and do some elevation Views by dynamic views then do some annotation on the drawing files, annotation for dimension is not working whenever I change the annotation scale the dimension text is not changing. pls check the video, I have try this DV in microstation alone, but annotation scale is working properly so I assume that prostructures the one has a problem.
