I have created 3D Model in Power-Prostructure (SS7), same i was tried to attached in Autoplant Piping (SS3) as an external reference, but in Autoplant Piping there is only one supporting file format i.e. .dwg for external references & Power-Prostructure file format is .dgn. So how i can resolved the issue?
One could create a native solid drawing in ProStructure and save as DWG and reference in, also if you want Export with Objectdata such as Beamsizes, you export as IFC,ISM or SDNF, and Import. if you have ProStructures for AutoCAD too.
It depends on your purpose.
Bentley Structural YouTube Channel
Bentley Technical Support
Johannes Michalowsky
User Success Support - Bentley Systems
ServiceRequest Manager
