Prostructures - calculations wrong
Im not sure what going on...
my units are set to imperial units in the design file and ive chosen an imperial bar code. It seems though that the bar bends are in milimeters and I have no idea how the weight calculation is being done.
10, 25ft #5 bars should not weigh 6695 lbs(?)
Parents Reply Children
  • The OBM model was a English based model. OBM has an export to PS option where it directly opens the OBM model. Is this not the desired workflow? Additionally, I can use a PS seed file but the resolution is much different than the supplied OBM model. I'm having an issue where each software supplies seed files and drawing seed dgnlibs that vary in resolution and this is posing a problem when using all the software together, especially with dynamic views and text placement.
