Can you help me?When I do secondary development about ProStructures,I cannot execute correctly the function "DeleteCutPlane" like the example as follows:
void PsEditModification::DeleteCutPlane(int handle)
Removes one cutplane from the object.
Sub Example_DeleteCutPlane() ' This example deletes a cutplane from an object by its handle Dim EditModify As New PsEditModification Dim Selection As New PsSelection Dim Id, Count, EHandle As Long Id = Selection.PickObject("Pick an object") EditModify.SetObjectId(Id) Count = EditModify.CutplaneCount If Count = 0 Then Exit Sub End If EHandle = EditModify.GetCutPlaneHandleFromNumber(Count - 1) ' Delete the polycut with handle number EHandle EditModify.DeleteCutPlane(EHandle) End Sub
Bentley Structural YouTube Channel
Bentley Technical Support
Johannes Michalowsky
User Success Support - Bentley Systems
ServiceRequest Manager
