Hi All,
I tried many times to see the soultion and unfortunately I hadn't....
Why i am not getting filled circle for any rebar that has hook at end - Any suggestions.
Balaji
Bentley Structural YouTube Channel
Bentley Technical Support
Johannes Michalowsky
User Success Support - Bentley Systems
ServiceRequest Manager
Hi Balaji,
You need to open your "display.sys" in Notepad and find the variable EDOT and set it equal to 1, save the file. If you were in the design file, reload the Rebar project by clicking on Rebar > Settings > Project > Reload. Then redraw the bar
RegardsDilip
