Please see image below.
I have modelled an arc plate, that has a straight LENGTH longer than the curved WIDTH. Prosteel has assigned the longer value as the WIDTH, and the shorter value as the LENGTH. In my drawing part list, I see the 866 dimension as both WIDTH (in name) and LENGTH.
I have the option "Length always largest value" enabled in global settings, but arc plates do not seem to respect this setting.
Is there anything I can do to enable length as the longest value for this plate?
Thanks for any help.
it will be always like this, the only way would a an extruded element and assign values manual
Bentley Structural YouTube Channel
Bentley Technical Support
Johannes Michalowsky
User Success Support - Bentley Systems
ServiceRequest Manager
AutoCAD 2017 - N 402.0.0 SP1.2ProSteel S6 - 08.11.11.207Australian LocalisationWindows 10 64bit
